Are these injectors too big?
Old Jul 17, 2002 | 08:59 AM
SmokinZ28's Avatar
I have a set of 30lb SVO's or a set of 24lb LT1 injectors. Which do you think would be better with a hypercrap chip (yes I know, dont try and get me to burn my own or get one from ed wright cause I'm swapping an LT1 in this winter)? Will the 30lb ones make it too rich?
9.5-1 350
ported edlebrock 6073 heads
crane 226/234 cam 114LSA .458/.473 lift
1.6 crane race roller rockers
accell SR w/ ported edlebrock base
AFPR
SLP 1 3/4 headers
3" flowmaster catback
Old Jul 17, 2002 | 09:41 AM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
I would go with the 24lb if you haven't gotten a custom burned prom for the 30lb. When you get a custom burned prom you can use the 30 lb so long as the the person burning the chip knows that you'll be using 30lb injectors and programs the chip having that in mind.
Old Jul 17, 2002 | 09:52 AM
tpi_roc's Avatar
Even the 24's will probably come out a little on the rich side.
Old Jul 17, 2002 | 10:30 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
tpi_iroc called it. The 24s will be on the rich side, if you absolutely must run them keep an eye on your BLMs, if you don't keep your FP on the low side you'll bottom at 108 and run rich across the board even in closed loop. If you do much driving in open loop you'll foul plugs and carbon up your chambers in no time flat.
30lb SVOs on a stock chip. Bwahahaha, you'd probably blow black smoke constantly if it even ran at all. You'd certainly wash down the cylinders and dillute your oil in no time flat, you'd be running over 30% rich.
Old Jul 17, 2002 | 11:27 AM
SmokinZ28's Avatar
Thanks, I'll put the 24's in and turn the FP down a little
Bubbajones_ya
Jul 6, 2024 08:32 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Nick McCardle
Sep 10, 2015 08:36 PM
