Will running with 7 spark plugs hurt my car??
Old Jul 16, 2002 | 06:39 AM
Don_89Iroc's Avatar
yesterday my car started chugging and loosing power so i checked my plug wire's and one of them is burnt almost all the way threw, my question is, is it safe for me to drive it that way? cause if not i need to find a way to work untill i can get new plug wire's Thanks -Don
Old Jul 16, 2002 | 07:07 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You can't buy 1 plug wire from an automotive store??
Old Jul 16, 2002 | 07:40 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I use to work at a local private owned parts store and we did.
But most chain part stores proably do not. besides he said "wires". So I guess he ordered a set.
Oh yeah, don you will be better off wating.
Old Jul 16, 2002 | 10:15 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The unburnt fuel is gonna ruin that cyl pretty quick..
Old Jul 16, 2002 | 11:29 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
yeah, don't run it long, if at all. When you do get the new wires, don't chuck the 7 old 'good' ones, in case you need another spare, just keep em in the trunk. You'll be back in the road in 10 mins flat if it ever happens again.......
Old Jul 16, 2002 | 07:44 PM
Don_89Iroc's Avatar
Thanks alot for the reply's, i have already drove it about 30 mile's or so like that, cause i had no other way to work, hope i dident F**K somthing up and i have 8mm Accel wires so i dont know if i can just buy one of them or not
Thanks a lot - Don
Old Jul 17, 2002 | 10:05 AM
tpi_roc's Avatar
gas in your oil
spun bearing
weeeeeeeee
(typing with donut in hand)
Old Jul 17, 2002 | 10:56 AM
AlexJH's Avatar
Engine: 5.7L V8
If the injector was disconnected as well, would it still be a problem?
Old Jul 17, 2002 | 10:58 AM
tpi_roc's Avatar
There's an idea
Old Jul 17, 2002 | 11:59 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Yeah, I'd just disconnect the matching injector. No fuel, no spark... no problem.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
justin57
Aug 20, 2015 07:05 PM
Exxon Limited
Aug 9, 2015 08:13 PM
djmarch
Aug 9, 2015 05:27 PM
