maf to speed density
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
i have a 89 tpi gta which is better maf or speed density? what do i need to convert from maf. how do i do it?
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Re: maf to speed density
Car: Death Mobile
Engine: 666 c.i.
If your however your engine is so modified that it is not able to run properly with the MAF, or your MAF or your 165 ECM died and the only replacement you can get is from GM (bend over please), then you MAY want to look at converting to SD.
I personally like SD and I fine "tuning the eprom" for SD much easier than MAF (that is more due to the MAF Scalar Tables than anything else). But if I had a perfectly fine running 1989 GTA that was not experiencing driveability problems due to the MAF setup, I'd just leave it alone.
well i would like to convert because i am going to start modifing the engine and also the mass airflow sensor acts up alot.
Car: 04 GTO
Transmission: M12 T56
If i had a MAF car, i figure i'd swap to SD as soon as the MAF went. No point in buying a MAF when for ess money you could go SD.
Otherwise, like Glenn said...
BumpaD82
Feb 26, 2016 02:57 PM
MikkoV
Sep 9, 2015 04:25 PM
