No Fuel Pressure
Old Jul 22, 2002 | 09:43 PM
Bad Blk Z's Avatar
No Fuel Pressure
Ok so i sold the black Z and now i got a 89 iroc 350 auto
heres the prob i have no power above 3000 rpm
none the motor wont even turn over 4200 it sputters so bad
i run a drive test on my scanner and when the car does this it is at full lean
so i pull out the old fuel pressure gauge and the car has 32 psi at an idle and 20 psi when i put it to the floor but when idling and i pull the vacume hose it goes to 38psi
heres the question is it the pump, the filter, or the regulator.
if it is the pump how do i know for sure...
also it has 13.8 volts at the pump at WOT
Old Jul 22, 2002 | 11:03 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Could be the pump on the way out, sounds like it just doesn't keep up under load. Or the fuel filter if it's not new. And did you check the voltage at the connector, aor ideally the voltage drop while it's running on the wrie back to it?.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
