Fuel Pressure at 34psi
Old Aug 3, 2002 | 03:14 PM
Larrys T/A's Avatar
Car: 1988 Pontiac Trans Am
Just put on a Accel Fuel Pressure Gauge, and it shows 34psi. I was just wondering if that was normal. Also i pulled the vacuum line, and the pressure went up to 44psi.
Old Aug 3, 2002 | 08:15 PM
Larrys T/A's Avatar
ttt OK guys all I want is the stock FP setting for 305 TPI
Old Aug 3, 2002 | 09:39 PM
90Form350's Avatar
I know what it feels like not to be answered on this board, so ill help.
40-42 psi is about right
Old Aug 4, 2002 | 09:35 AM
Larrys T/A's Avatar
Thanks 90Form350
Old Aug 4, 2002 | 12:21 PM
Chris Ja's Avatar
You always pull the vac line when checking the fuel pressure. Min rec factory setting is 42. On built engine fuel pressure should be raised 2 points at a time while fine tuning. I run my fuel pressure at 48psi. I have a lot of mods. Hope this helps.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
