Superram and injectors
Old Aug 5, 2002 | 03:02 PM
ssbowtie1's Avatar
Hi everyone, I just finished installing my SR and seem to have a problem with the fuel injector plugs. Is there any way to plug all the injectors in with the plenum on or do you have to do it before the plenum goes on. Thanks for any help.
Old Aug 5, 2002 | 03:47 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
It can be done after its installed with some patience. You do have to trim some plastic off the injector plug #'s 7 & 2, b/c they are up against the runners. I fish them in there with needle nose pliers.
Old Aug 6, 2002 | 01:10 AM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I can get them all with my hands. Didn't have to trim anything either. I have to use a small flathead to help get the coldstart injector plug off though.
If you didn't already, turn the injectors so they the plug faces away from the runners. This should give you just enough room.
Practice makes per......well easier anyways.
Old Aug 6, 2002 | 10:55 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
so what are you going to do with that SR Rick?
Old Aug 7, 2002 | 03:49 PM
Ricktpi's Avatar
i swapped it to a guy for a Stealth Ram & an undisclosed amount of cash.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
