bad miss when cold
Old Aug 5, 2002 | 06:52 PM
bottlefed89's Avatar
bad miss when cold
okay this is my current problem....
when my car temp is cool it has a bad miss but only when in gear and it starts around 2500 3000 rpm...
when the car reaches operating temp of around 180-210 the miss goes away and everything is fine
recently replaced...... cap, rotor, wires, plugs checked module and it read okay..
anybody know what this is? i dont wanna play guessing games and just go buy stuff..
Old Aug 6, 2002 | 10:20 AM
tpi_roc's Avatar
Hook up a scanner to the car and see if you can find out whats going on if you dont want to guess.
Old Aug 6, 2002 | 05:19 PM
did that... it shows no codes and my S.E.S light isnt on
Old Aug 6, 2002 | 05:20 PM
tpi_roc's Avatar
The scanner isn't about codes....
Codes are simply a sensor reading outside of a threshold. The scanner will tell you data like lean/rich to much/little timing, iac steps, anything and everything, and from that you can try to figure out what your miss is.
Cornholio7979
Sep 20, 2018 02:31 AM
someone972
Aug 30, 2015 12:52 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
