headers
Old Aug 6, 2002 | 11:07 PM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
headers
can i put headers without a.i.r. hookups?
is that part of the smog pump?
if i remove the pump will it disable the a.i.r.?
Old Aug 7, 2002 | 10:56 AM
tpi_roc's Avatar
Remove the pump, plug the hole in your exhaust, and get headers without A.I.R tubes and you'll be set.
Old Aug 7, 2002 | 12:59 PM
demon138's Avatar
what hole in my exhaust
Old Aug 7, 2002 | 01:44 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
There is a pipe that runs from the cat up to a hose that runs to the black box for the smog stuff. IIRC you will need a 1/2" cap for it. You will also need a smaller belt.
Old Aug 7, 2002 | 02:52 PM
demon138's Avatar
what size plugs and how many will i need to block off the air
Old Aug 7, 2002 | 03:26 PM
demon138's Avatar
what do i do with the two electric connections that go to the black box
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
