88 1 Ton GMC TPI swap
Old Aug 8, 2002 | 09:19 PM
ForceFed's Avatar
I built a 355 with bowtie heads for my pickup, anyway i need to the rest of the info for getting it running, i got a walbro 255 pump for it, i need bigger fuel lines im assuming?.. Now to the confusing stuff, i got a TPI setup that is off a GTA according to the owner, it has the older style lower intake which makes me believe that its off a pre 87 motor? meaing the inner 2 bolts are angled like the rest, is this a MAF setup or SD? i have a harness and computer coming to me but i dont know if it will work, should i send my stock TBI harness out to get changed to a TPI setup? which would i rather be running SD or MAF?, compression is around 10:1 and im running a crane compucam in it with unported bowtie heads, if anyone see's any issues with this build feel free to insult me, sorry for the mini novel
thanks in advance for any idea
John S
Old Aug 9, 2002 | 10:21 AM
tpi_roc's Avatar
Re: 88 1 Ton GMC TPI swap
John S
I dont think you'll need the bigger lines unless you NEEED the bigger lines. If that makes sense If your bolt holes are the pre 87 style then theres reason to believe it came off of a MAF car, however that doesn't make any difference to what harness/ecm you *need* to us. The more desireable system of the two is speed density. If you haven't already paid for your cam I'd just like to state that I recommend against compucams, good luck.
gta90
Sep 15, 2015 04:00 PM
ezobens
Aug 19, 2015 10:29 PM
Catcher55
Aug 15, 2015 07:08 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
