SVO injectors
Old Aug 9, 2002 | 01:21 PM
86ZZ4's Avatar
SVO injectors
Ok ,this has been beat around for years now,does anyone really know for sure on the theory that SVO injectors are rated at a different pressure than the GM ones? for example SVO 24# equal to approx 26# GM, 19# equal to approx 21# GM?
Old Aug 9, 2002 | 01:50 PM
Guest
Guest
Posts: n/a
Its true. I have 30# injectors and with the injector constant at 33#'s the car ran the same rich/lean wise as it did with the stock 22#'s.
Why? Well, thats because Ford doesnt run the same pressure as GM does, and since those injectors are supposed to be used in a Ford they rate them at the Ford pressure so that the #/hr number is useful information for a Ford guy who's changing things.
Old Aug 9, 2002 | 02:48 PM
86ZZ4's Avatar
Yeqh,Ford FP is usually 36-38 or so,just wasnt sure if there was an SAE type rating system for flow rates etc.Myself, I felt it held some merit,cause my car should not like the 19# SVO injectors at all if there wasnt some difference.Its kinda going by TPIS's theory of smaller squirters @ a higher pressure ,my SVO 19#'ers are @ 51 psi.And if it was running out of fuel/too lean it wouldnt MPH close to 103 MPH in 4th gear of a 700r4.My biggest problem is the 85 ECM im currwntly running,just not a whole lot that can be messed with PROM wise. well, thanks for the info MAX.
Old Aug 12, 2002 | 08:18 AM
86ZZ4's Avatar
so on average, add about 2lbs to the rated flow on SVO to get equivlant GM flow?
Old Aug 12, 2002 | 01:17 PM
Guest
Guest
Posts: n/a
new flow= [square root(new pressure/old pressure)]*old flow
That makes 24# injectors around 26. 19's around 20.5ish. As usual, your results may vary.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
