cold start problem please help someone!!!!!!
Car: 86 trans am
Engine: 5.0 tpi gtauto ramair and notch
Transmission: 700 r4
i have a 86 t/a 5.0 H.O. this prob just started when the car sits overnight it will not start unless i hit the accelarator 1 time while cranking then its fine all day? any sugestions would help me out alot btw tune up was done 6oo miles ago fuelfilter included.mas was replaced and computor was cleared no codes at this time thanks
Is it Tuned Port Injection or carb!!!!!
Never heard of an "HO" TPI engine!!! Only carbed engines were marketed as "HO" to my knowledge!!!
If it's carbed you're supposed to step on the gas before starting, to set the choke!!!!
If it's TPI, check your Throttle Position Sensor voltage!!!
You seem to like a lot of exclamation points, hope these were enough for you!!!!!!!
Car: 86 trans am
ok thanks i was told about the h.o. but dont know that to be a fact but it is a tpi motor.i will check the sensor but do you think it would be that if after the car starts the first time by hitting throdel and then is fine the rest of the day???? it just has me confused thanks
92camaroJoe
Aug 13, 2015 06:07 AM
