Trottle shaft inside TrottleBody
How Do I remove it ? My dad will port my TB for me .
Do I have to cut one end ? or grind it ???
Afterward do I have to drill a hole in the shaft and a screw so it will hold together ?
Guest
Posts: n/a
You have to take out the throttle plates by grinding off the screws on the back, unthread those, and then take off the tang and bent over area on the TPS side of the shaft. Once you do that, you should be able to pull the shaft out. Cleaning off any burrs before you pull it out of the TB might be a good idea.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I did a writeup on boring out a throttle body to 52MM. I never sent it to Dirk for posting..
http://www.joesperformance.com is my website, you'll find it their..
-- Joe
-- Joe
KO1
16
Oct 15, 2015 05:00 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
