I need help with this painless wiring harness!!!!
Old Aug 19, 2002 | 03:30 PM
89Irocz23's Avatar
I thought I finished it all and everything would work. Well I have the fuel pump wired with the 18 circuit so it comes on when I turn key. Well I tried to start it and I seem to not be getting spark. I pulled one of my plugs and it doesnt smell like fuel at all either. I had John do my chip and he removed the vats so I dunno anymore. I have all new sensors and relays and all that. Accel coil seems to be hooked up right. When I turn key (not start) the check engine light is on(which is should be until its running) Any idea would be greatly appreciated.
Old Aug 19, 2002 | 05:44 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Put on a heavy glove. Put a screwdriver in the plug wire and hold it close to a bare spot on the block ... does it throw a spark?
Old Aug 19, 2002 | 08:37 PM
89Irocz23's Avatar
No it doesnt throw a spark. Im going to take dist out tomorrow, im thinking while it was out, while I was doing lt1 intake I might of damaged the dist while it was out.
Old Aug 24, 2002 | 02:25 AM
onetontj's Avatar
There is the pink wire for the computer which sounds like you got hooked up right. Then there is another wire(I think red), that needs to be hooked up to the large terminal on the starter.
That help at all?
CJ
Old Aug 24, 2002 | 11:36 AM
89Irocz23's Avatar
I ended up getting it running. I forgot to hook up the pigtail with the tach and coil power. I figured it was just for the tach so I didnt need it hooked up at that time, but i was wrong.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 21, 2015 01:54 AM
