how much hp can a tpi system support
Old Aug 21, 2002 | 05:44 PM
86 sc's Avatar
i'm new to tpi so help me out, with a few simple mods how much hp can a tpi system handle? i know they have tq but what can you do to increase hp? i'm asking because i thought a 383 would be fun with tpi. thanks jason
Old Aug 21, 2002 | 06:37 PM
5SIZ's Avatar
Car: 1987 IROC-Z
the average tpi system can support up to well over 300hp if im not mistaken, but, in a 383 or 350 or any size engine I definatly suggest you invest in aftermarket intake manifold & runners. this will help air flow considerably.
Old Aug 21, 2002 | 07:48 PM
86 sc's Avatar
would a manifold, runners, and thortlebody, be able to support 450-500 hp, all those parts being good one's of course?
Old Aug 21, 2002 | 08:12 PM
Astro's Avatar
For 450-500 HP, i would suggest talking to John Millican about getting a modified LT1 intake. Will breathe great for higher horsepower than a ported TPI could, and for about the same or less money.
Old Aug 21, 2002 | 08:19 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
Agreed. A maxed out TPI (runners, manifold, TB, ported plenum) can probably support up to 350+ HP....but if you wanna go higher than that an LT1 intake would be great
Old Aug 21, 2002 | 08:54 PM
SHO350's Avatar
Car: 1991 Trans Am
Depends on the type of air metering system. A MAF car can support up to around 325hp. After this point the MAF can become a restriction to air flow. Speed density systems have no restriction to air flow and can theoretically support an unlimited amount of horsepower.
Old Aug 21, 2002 | 09:08 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Yeah, stock TPI parts with some porting are good enough to make somewhere over 300hp and have been on some low 13 second cars and even beyond with some magic. I'm interested to see what can be done with a siamesed stock base and stock runners, since theoretcially you don't need large tube runners with a siamesed base since you have 2 for each hole to breath through now.
But on a big inch motor stock TPI wouldn't be too much fun.
Old Aug 21, 2002 | 09:11 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Isn't there a guy on here running like a 12.5 w/ a TPI setup? I can't remember his name though. He's a teacher...and has owned the car since new...that's all i remember from his site.
Old Aug 21, 2002 | 10:02 PM
86 sc's Avatar
wow maby i'll just stick with carb, and sneek pass the emission guy!
Old Aug 22, 2002 | 09:53 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
N/A or ??
N/A prolly like 500 would be the limit on a ported aftermarket setup..
-- Joe
Old Aug 22, 2002 | 10:04 AM
86 sc's Avatar
no nitrous or blower for me
Old Aug 22, 2002 | 10:39 AM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Assuming a 18% drivetrain loss, I'm making about 330 hp at the crank with a completely stock TPI setup, and a MAF sensor. I think that the TPI can make a lot more power than most people think it can, but it's really finicky.
Old Aug 22, 2002 | 02:25 PM
86 sc's Avatar
what kind of 1/4 times do people get with tpi?
Old Aug 22, 2002 | 04:37 PM
Gruvin84SS's Avatar
That would be Mike Davis. He ran his fastest time of 11.94 with a Long Tub Runner setup. Of course that was a ported plenum, AS&M runners, and Edelbrock siamesed intake(the holes on this siamesed edelbrock are huge, I know cause i have it, but not currently installed). Mike has since gone to another form of EFI. He also is Heavy into Prom Tuning.
The Vortec setup with PROM calibration would be a nice motor and have 400+HP, but it is still at 4800RPMs due to the "Tuned" runner length. HTHs
Old Aug 22, 2002 | 05:25 PM
iroc22's Avatar
Please don't. Stick with MPFI. A well tuned aftermarket MPFI setup with proper matched injectors can support up to 600hp. Sure it's expensive, but you'll be more happy with it.
Old Aug 22, 2002 | 06:22 PM
86 sc's Avatar
thats true but i'm in college a freshman at that, so i don't have much fundage
Old Aug 22, 2002 | 07:25 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
well then wait. But dont put a carb on it or you wont be happy. I'm in college (junior) and I've just been adding to my car during the summers. Be patient....slapping a carb on isn't the solution.
Old Aug 22, 2002 | 09:03 PM
iroc22's Avatar
Definitely not. Waiting seems to be the best solution right now.
Old Aug 23, 2002 | 09:18 AM
86 sc's Avatar
any efi's for a 454?
Old Aug 23, 2002 | 10:36 AM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Theres a 454 TBI setup that came on the early 90's (i think early 90's?) 454 SS chevy trucks. You can find those easily on ebay. There's also some aftermarket setups you could use, but they cost some $$$$$
Old Aug 23, 2002 | 01:39 PM
iroc22's Avatar
Accel makes some Ram setups for big blocks and Holley has some MPFI systems for BB's as well.
Old Aug 23, 2002 | 02:58 PM
86 sc's Avatar
i wounder what kind of performance you could get with a tbi setup on a bbc?
Old Aug 23, 2002 | 04:16 PM
Ed Maher's Avatar
Car: 04 GTO
They work so good that all the fast ones rip it straight off and swap to carb. The TBI 454 SS was a performance joke
Old Aug 23, 2002 | 04:37 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
you got that right. Those things only run like a mid 15 stock if i'm not mistaken....but feel free to correct me if i'm wrong.
Old Aug 23, 2002 | 05:22 PM
86 sc's Avatar
ok bad idea.
Old Aug 23, 2002 | 05:27 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Now those aftermarket systems are a different story. If you read any chevy mags. or such, there's always a guy w/ a fuel injected big block making MUCH power. Problem is that those systems is that they cost 2-3 grand! So carb the obvious choice on a BB...at least for the average guy.
Fast355
Dec 2, 2016 06:33 PM
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
