ecm question please help!!!!
Old Aug 27, 2002 | 01:50 PM
aaronkark's Avatar
I was curious if anyone knew if you could use the v6mpfi ecm in exchange with a 305tpi ecm. Also would it matter if you had automatic or manual? By the way both cars are 1988. Thanks Aaron
Old Aug 27, 2002 | 10:15 PM
xmind2006's Avatar
Car: '86 Iroc-z28
Below is the link I found from the board when I had an ecm question.
http://www.cruzers.com/~ludis/p4xref.html
If you have both cars there you can check the ECM numbers. It takes max of 5 minutes to remove the ECM from behind the passenger dash. Just take the 3 screws off from the panel above the passenger's feet, 2 screws that hold the ECM bracket in and carefully remove the connectors as not to break the clips, and just compare numbers to make sure.
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 10, 2015 08:42 AM
