Mechanical Tpi????????
Old Aug 31, 2002 | 08:18 AM
DEATH88305's Avatar
Car: 1988 IROC CAMARO
Engine: 5.0 F.I.
Transmission: 700 R 4
IVE BEEN HAVING THIS IDEA OF CONVERTING A TPI SYSTEM INTO A MECHANICAL FUEL INJECTION, SUCH AS HILBORN, ENDERLE, ENGLER, ECT. THE PIC BELOW IS A FABRICATED TPI SYSTEM, NOTE THE INJECTORS, THEY ARE NOZZLES FOR A MECHANICAL SETUP, IM THINKIN BELT DRIVE HILBORN PUMP, METERING BLOCK, BARREL VALVE AND DISTRIBUTION BLOCK, WHITH THE PROPER NOZZLES AND PILLS FOR GAS TO DELIVER THE SAME FUEL AS 19LB INJECTORS, AND 58MM THROTTLE BODYS, OF COURSE THE FUEL PUMP IN THE TANK WILL BE DELETED....
JUST A THOUGHT IM THINKIN ON BRINGING TO REALITY.....
.......JOHN
Old Aug 31, 2002 | 12:19 PM
89 TA's Avatar
Car: Trans Am/Kenworth
Engine: 383/435 Cat
Transmission: T5/10 speed
Why?????
Old Aug 31, 2002 | 12:28 PM
kevinc's Avatar
Car: 1982 Z28
Very cool. What's next, replacing your computer's keyboard with a stone tablet and chisel?
Old Aug 31, 2002 | 01:49 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Mechanical Tpi????????
.......JOHN
Have you driven a Hilborn on the street?.
It's light having an off on switch for a gas pedal.
If you want to go to a Bosch mechanical set up you MIGHT like it, but even with lots of experience they take FOREVER to get right.
You'll never match the performance of EFI with a Correct calibration.
Old Aug 31, 2002 | 04:40 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
A friend of mine has an old mercades mechanical FI engine.
Saw a picture of the hp/torque curve. Torque curve looked like a flat line with peak torque at all rpms.
I was impressed! Not sure if that had to do with the fact that it eas mechanical or what, but just wanted to toss that in.
(electrical problems suck IMO, so it might not be too bad of an idea)
Old Aug 31, 2002 | 08:05 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Is that a GM TBI throttle body stuck to the end of that plenum? WTF?
Old Aug 31, 2002 | 11:35 PM
DEATH88305's Avatar
Engine: 5.0 F.I.
YEP, I FOUND IT HERE..........
http://members.tripod.com/lyc_42/chevy/sb/sb.htm
SCROLL DOWN, ITS THE LARGEST PIC........
gta90
Sep 15, 2015 04:00 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
