cam for 400 sbc
Old Sep 1, 2002 | 07:43 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
cam for 400 sbc
I would like to know what cam to use in my 400 sbc it will have tpi for now till I can do a lt1 intake swap and speed den. ecm swap(no flames about tpi!) I just would like some Ideas for cams to choose from. I do know how to burn my own chips so I can get a cam that will be some what agressive
Old Sep 1, 2002 | 07:46 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
sorta depends on what heads you have on your motor because poor flowing heads and a big cam= disaster. Also will this vehicle have to pass emissions?
Old Sep 1, 2002 | 07:57 PM
Engine: ls1, LB9
well, The heads on it now are stock (1.94?) the best I can tell, the casting# does not say it just says they are 400 heads. and no emissions here. and It should be 9.5:1 if I remember right
Old Sep 1, 2002 | 08:10 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
The LT4 hot cam will work good since you probably don't have the capapbility of the using the higher RPM band due to the heads you have on your car. I would seriously swap the heads out when you're doing the cam. At that point, I would go with a CC306.
Old Sep 1, 2002 | 08:50 PM
Engine: ls1, LB9
is the lt4 hot cam hyd. roller? I was thinking I may need to use reg hyd. lifter cam.
Old Sep 1, 2002 | 08:53 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
yeah its hyd. roller. I can't think of any flat tappet cams off hand.
Old Sep 2, 2002 | 10:55 AM
Engine: ls1, LB9
I want to through some more in here and see what you guys think. I have some solid roller lifters that I was thinking of using but, I am a little concerned about using because from what I understand I will need a special #1 cam(no big deal yet) #2 non self alighning rockers #3 hardened push rods #4 screw in studs #5 stud gurdles + tall valve covers to clear all of that #6 some sort of cam retainer. I really think that a hyd. flat tappet cam would be better. right now my 350 is deep in to 13's so the 400 should get me low 13's or high 12's right?
Old Jan 30, 2003 | 06:59 AM
85TPI400's Avatar
Bringing back an old topic here, Im interested to here peoples suggestions for cam with a 400 TPI engine! I am thinking of upgrading mine but NEED to maintain a good idle. I was considering a Summit racing 224-234 dur @ .050 with .463-.488 lift. Anyone have experience with this cam or similar in a 383 or 400 with a modified LTR TPI set up?
Old Jan 30, 2003 | 08:39 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I may be able to help you out
I like the cam in my sig...I have no problem keeping a flat tappet cam in my 406 and it lopes along pretty well (at least it did with stock heads)...
The way I looked at it...I wanted a cam that would match my stock-type rebuilt shortblock...cast pistons, stock prepped rods and cast crank...with a powerband to about 5800 with a 6000 (max) redline...
The cam I picked out was a pretty great find being that it has the proper LSA for the EFI setup.
I like the power of this cam...and I bought it when I was running a stock longblock with the TPI setup...not too bad...I could have used some more tuning, but I was happy...
HTH,
C409
Sep 23, 2015 04:30 PM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
