13's yet?
13's yet?
SHould i go 13's yet with my setup?
86 IROC
91 alum head vette L98
Open element K&N
TPIS big mouth lower intake manifold
Edelbrock TES headers
MSD 8.5 wires
Bosch platinums
FLP level III trans
12 inch 2800 stall tq converter
3.73 rear end
Trans cooler
275 width street tire
if not, could i benefit from a good prom burn?
Thanks,
Matt
86 IROC
Open element K&N
MSD 8.5 wires
Bosch platinums
FLP level III trans
3.73 rear end
Trans cooler
Thanks,
Matt
You should be able to see 13s with that setup, as long as you can get good traction. What kind of tires are those? I would invest in some slicks or drag radials....you'll notice a huge increase in traction from those alone. As for the prom burning, get it done anyways. I'm starting to program my own proms right now, and it isn't all that difficult. Good luck, hope this helps.
thanks for the reply. Im running a real piece of $*&# tire right now. THey are ultras, i basically got the cheapest thing so i could get my car back on the road (poor college student).
THanks,
Matt
THanks,
Matt
Car: 1987 Trans Am GTA
Engine: 5.7L 350 V8 TPI
Transmission: Automatic 700R4
CamaroX84 what kind of program u using to read those bins? I'm having a hard time finding ones that work for me. Ive used BMCS Engine Tuner, and Cat-Turner, and no luck. If u have some ideas or what not, or u need more info, please tell.
If you dont have alot of cash you should give porting a try and add a cam. Then I would go with the chip burning and whatever traction mods you need. That would get you well into the 13s nicely, if what you have doesnt.
greg
greg
Car: Damn
Engine: This
Transmission: New Stuff
I would hope so. Shouldn't be a problem unless it doesn't run right or you can't hook, that converter will make it a chore.
If I had headers and a small converter I'd be well into the 13s on my 92, so you should be there with what you have there.
im glad ive gotten replies. thanks again. future plans include the Lt1 intake from j millican. I want to have a setup that will allow me to build a great finished product, but not be waiting on anything. (if that makes any sense) Next mods in order i think will be LT1 intake, cam and heads. (will probably be a while). While i want a great finished car (are they ever finished?), i want a cam that can wait for the heads and not be unstreetable. And should i go with something like AFR 190s or port the snot out of the AL heads? what will be more cost prohibitive and waht will provide the best gains?
thanks for taking the time to read.
Matt
Matt
