fuel pressure jumping around when driving
Old Sep 3, 2002 | 02:54 PM
ScreaminDeamin85Z's Avatar
very strange problem, it is not constant. when i was driving back to school i noticed the pressure jumping all over the place. from 42 while on the highway and would i would excelerate it would go as low as 22, then if i eased off the gas it would rise back to 42 or sometimes higher. the car also will not idle, no matter what, it will just die. anyone? i am at school and dont really have alot of time to spend guessing on things but a general idea of what could be causing this woul be great.
Old Sep 4, 2002 | 11:45 AM
tpi_roc's Avatar
Does it ever go HIGHER ?
like extreme pressure?
If not i'd say maybe your fuel pump is giving up the ghost
if so maybe your diaphram in your fuel pressure regulator is misseated or torn.
Old Sep 4, 2002 | 01:10 PM
Morley's Avatar
Fuel pressure changes while moving the throttle is normal, after all the regulator is vacuum operated and the vacuum in the engine changes as the throttle is opened or closed.
Not idling....what is the pressure when you "attempt" to idle?
Old Sep 4, 2002 | 01:12 PM
tpi_roc's Avatar
20psi seems a bit low even with excess or lack of vacuum
dont it?
Old Sep 4, 2002 | 01:40 PM
Morley's Avatar
dont it?
Nope, mine does that, has all the time, depending on the weather conditions at the time. As barometric pressure changes, so will your fuel pressure readings at any given vacuum.
Old Sep 4, 2002 | 01:45 PM
tpi_roc's Avatar
hm
I've never seen mine that low
oh well, hope that means you dont have an issue ScreaminDeamin85Z
Old Sep 4, 2002 | 03:04 PM
well it hasnt done it since then...that i saw on my gauge. but it still wont idle for $hit.
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
