87 or 89 Injectors
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
87 or 89 Injectors
From what I understand, in 1989 GM began using better injectors that created a better spray pattern, were more reliable, etc. I have a set of those injectors but one of them is bad.
Would it be worth my time to replace my 87 Injectors with a set of matched 89 Injectors?
If so, Will the 89s plug directly into my 87 base and runners, and plugs?
the reason I am asking is I am considering sending my extra set of injectors to have them matched and cleaned...
thanks
John
thanks
John
Car: Iroc-Z
Engine: 355 AFR'd HSR
Well, in '89 the injectors were the exact size they were through all the years. (Physical size) They will fit perfectly, make sure to use NEW o-rings. On your 87 don't you have a cold start injector?? Just wondering.
By the way, are you putting these in a 350? If so, remember that the 305's got the 19#/hr injectors and the 350's got 22#/hr's.
I picked up the TPI unit from an 89 305, so they should be 19's...
thanks
thanks
thejimsterz28
Sep 15, 2015 04:37 PM
