Great MSD 6AL Location!
Old Sep 4, 2002 | 07:21 PM
Oscar's Avatar
I debated on where to put my MSD 6AL box for awhile. I did not like the usual locations because the box looks like it's been shoved into a corner and hanging. Heat also a consideration and definetly appearance. I did not want to remove the washer tank or anything else. I wanted a location where it looked like it belonged so here it is. I fabricated this small bracket and attached it with wing nuts above the battery to make removal easy in the event that I needed to get to the battery. The box is mounted to the bracket, bracket removes in a minute and can be temporarly seated on the coolant resevoir for accesss to the area.
Whatcha think?
Old Sep 4, 2002 | 08:08 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Looks good. Clean engine bay too. Nice
Old Sep 4, 2002 | 08:14 PM
'91_Z28_droptop's Avatar
Iwas thinkin' the same thing
Right on brotha'. I put mine in the exact same place. I thought, why bother with trying to shove it in a place where no one can see it or have to remove something. Just right smack dab on the battery.
Old Sep 4, 2002 | 08:24 PM
Oscar's Avatar
Cool dude! Yours is sitting on the battery?
Mine sits about 2 1/2 to 3" above the battery. Any corrosion or acid getting into it sitting on the battery?
Old Sep 5, 2002 | 03:36 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
how did you mount in on top of the battery?
Old Sep 5, 2002 | 05:02 PM
Oscar's Avatar
Here's a couple of extra close-ups of the bracket.
Old Sep 6, 2002 | 01:10 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Here is mine....
Old Sep 6, 2002 | 10:13 AM
pokes87iroc's Avatar
nice bays guy they look good and that a pretty slick idea. it would really be a good place if u mounted the battery in ur spare tire compartmeant. i think i am going to mount mine there when i get one do they help with perf at all?
Old Sep 6, 2002 | 01:37 PM
Oscar's Avatar
I must say that I immediatley noticed a much quicker throttle response. I mean much quicker...I also noticed the idel is incredibly smooth. When I punched it I did notice it pulled better at the higher rpm's. I'm not sure about the gas milage cause I haven't had for a full tank yet, but I believe I may be getting better gas milage. Needle seems to be moving much slower.
Old Sep 7, 2002 | 12:07 AM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
that's too close to a corrosive environment to me.
...I didn't have to extend any wires using the MSD adaptor harness
Old Sep 7, 2002 | 12:31 PM
5SIZ's Avatar
Car: 1987 IROC-Z
In all honesty, that is a really good idea, you should make a tech article on how to fabricate the bracket & what youll need etc.
Seeing as how I have my A/C removed, when I get my MSD 6AL it will be on the firewall right were the A/C used to be.
Old Sep 7, 2002 | 01:15 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
I used to have mine near the battery too but after a while it started to get corroded. I had to scrape the rust off and sand it and then paint it. Now it is where all the other electronics are. I also put the tach adapter on the firewall.
<img src="http://home.earthlink.net/~ozvresto/GTA/images/msd.JPG">
-Ozzy
Old Sep 7, 2002 | 11:51 PM
Oscar's Avatar
Ozzy.
How close to the battery was yours? Mine is at least a couple of inches above. Doesn't touch the battery at all.
Old Sep 8, 2002 | 11:26 AM
IROC57TPI's Avatar
Why is it that some people need to use a tach adapter? I didn't use one, and I also didn't use the MSD harness adapter. I wired my MSD myself and hooked the tach wire up to the white trigger wire for the MSD. It works fine as does the tach.
I guess you guys just might have too much $$ to throw around
Old Sep 9, 2002 | 06:04 AM
Ozzy88GTA's Avatar
Engine: 5.0 TPI
It was just next to the battery, towards the rear by the steering box. I guess I should have known better.
I hooked mine the same way. Some other people said they didn't have a problem either but mine was acting up bad. After I put the adapter it worked like it's supposed to. Also, I don't really have a lot of $$ to throw around is just that sometimes you've got to do what you've got to do to make it work.
Later,
-Ozzy
Ozzy88GTA's Avatar
Engine: 5.0 TPI
Sorry, double post.
-Ozzy
Old Sep 9, 2002 | 11:54 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I made 2 brackets & hung it off the upper tie bar on the drivers side, over the vapor canister, you want to get it as far away from the ECM as possible, to avoid interference.
Check for image:
http://mywebpages.comcast.net/ricktp...uper%20Ram.jpg
Thornburg
Aug 30, 2015 08:05 AM
overdriv
Aug 20, 2015 03:52 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
