LS1 Fuel Injectors
Old Sep 6, 2002 | 02:49 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
LS1 Fuel Injectors
After searching on this board I found that LS1 fuel injectors will fit in the TPI fuel rail as long as you don't put the retaining clips in. Someone mentioned something about LS1 injectors LB/hr rating being a different PSI ratting then TPI injectors, is this true?
What PSI are TPI injectors rated at?
What PSI are LS1 injectors rated at?
Old Sep 6, 2002 | 02:58 PM
True Power's Avatar
I know of someone selling some LS1 injectors. They are out of a 2000, i believe. They're 26pounders, but i'm not sure what PSI they're at. I'll ask around, see if i can't find out
Old Sep 6, 2002 | 04:17 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Are LS1 injectors better then LT1 injectors? Which ones should I get?
Old Sep 7, 2002 | 11:54 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
anyone?
Old Sep 9, 2002 | 11:02 PM
S10Wildside's Avatar
305 TPI: 19lb/hr
350 TPI: 22lb/hr
4.3L V8 LT1: something less than 24lb/hr
5.7L LT1: 24lb/hr
5.7L LS1: 26lb/hr
ZO6 LS6: 28lb/hr
Old Sep 10, 2002 | 02:53 PM
kevinc's Avatar
Car: 1982 Z28
Originally posted by S10Wildside
305 TPI: 19lb/hr
350 TPI: 22lb/hr
5.7L LT1: 24lb/hr
5.7L LS1: 26lb/hr
ZO6 LS6: 28lb/hr
Those last two are rated at 4 bar, not the same 3 bar standard as the others. When you do the math to correct to 3 bar pressure you're seeing 22.x and 24.x lb/hr, respectively.
Old Sep 10, 2002 | 04:03 PM
Hmmm, so you're saying that if I want 24lb/hr injectors on my TPI electronics then I have to use either LT1 24lb/hr or LS1 28lb/hr injectors? You threw me off on the 3 and 4 bar thing.
Please let me know
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bamaboy0323
Sep 3, 2015 06:07 AM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
