mementary bogging problem
Old Sep 10, 2002 | 07:20 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I tried posting this in the Power adders to no avail.
When I power shift, the car falls flat on its face. It didn't used to do this before. If I granny shift or ease into the gas its fine. It does NOT do it when I'm spraying.
I'm throughing codes 24(VSS) 32(EGR) 33(EST) and 42(MAP).
Any and all help is greatly appreciated. I want to fix this prob. before I swap my intake and cam.
Old Sep 10, 2002 | 10:35 PM
89 TA's Avatar
Car: Trans Am/Kenworth
Engine: 383/435 Cat
Transmission: T5/10 speed
I'll let you know in a couple of day's. I am having the same problem and I already tried everything else. my last option is the egr. I got a wd40 can and spray'd the s@#t out of the egr and the car will run fine, but after a while it will go back to bogging.I went to autozone but they had to order it. Will get it in a couple of days.
Old Sep 11, 2002 | 06:46 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
I don't have an EGR. No valve. No passages in the heads.
db057
Apr 28, 2019 07:45 AM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
