stealth ram AFPR
Old Sep 12, 2002 | 06:29 PM
cobrakiller1989's Avatar
stealth ram AFPR
does anyone know of an AFPR that will work on the stealth ram, my fuel rail kit didnt have an adjustable one so now im stuck at this pressure. Also, i called holley, they had no idea what i was talking about and they also said that the FPR that i have is set at a constant pressure(43psi i think) why is there a vacuum line going into it if it constant?
thanks
Old Sep 12, 2002 | 07:07 PM
e-man's Avatar
Car: 89 formula
Engine: 383
The regulator is the same as a 84-87Buick GN,Regal turbos V6.You need the VAC line to adjust the pressure for loads on the engine.
Old Sep 12, 2002 | 07:30 PM
thats what i thought, but the guy at holley said its always that pressure...oh well, ill just get that regulator you suggested, thanks alot
Old Sep 13, 2002 | 06:42 AM
Doug Flynn's Avatar
You need a vacuum line on any regulator with multiport so the the pressure differential in the intake stays the same. The regulator is set to open at 43 psi. If the rail sees 43 psi and the intake vacuum is at 5 psi, then you'd really have 48 psi without the vacuum reference line.
The regulator is a "1 to 1" regulator. When the 5 psi of manifold vacuum is applied to it, it will reduce the regulated pressure to 38 psi for a correct differential pressure of 43 psi.
Clear as mud?
A supercharged engine is just the opposite, if you run 10 psi of boost it will add 10 psi to the regulator but you still will have a differential pressure of 43 psi in the intake even though the rail is at 53 psi.
The DIFFERENTIAL pressure in the intake will ALWAYS be 43 psi if you use the vacuum line.
Old Sep 13, 2002 | 10:14 AM
David 91RS/Z28's Avatar
Re: stealth ram AFPR
thanks
Thunder Racing has the adjustable regulators for the Stealth Ram. You might give them a call.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
mfp189
Sep 27, 2015 09:25 AM
