Stealth Ram....what can I do for the fuel lines????
Does anyone have part numbers of what I need to hook up the Stealth Ram to the fuel lines on the car? Also, where can I find these? Thanks.
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
Would these work? They are for sale since I need bigger lines for my YS Trim application. 319-373-5321.
http://community.webshots.com/photo/...47047006IZCilC
http://community.webshots.com/photo/...47046994qfzgjg
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I used -6 braided steel hose. On the regulator (drivers side) a straight male flare with 180 deg hose end. On the feed side (pass) I used a 90 deg male flare & a straight hose end & fed it in front of & under the distributor. I cut the factory fuel lines right where the steering shaft comes out of the firewall & used Russell 3/8" & 5/16" hard line to -6 male flare adapters & 90 deg hose ends. All fittings were Russell.
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
