please help- fuel question
Old Sep 15, 2002 | 04:10 PM
j_bonham69's Avatar
Ok i have an 89 tpi 305 trans am. it broke down and i tried to start it and it wouldent. i sprayed carb cleaner into it and it started. i thought it was the fuel pump so i replaced it. after i replaced it i tried to start it and it still wouldent start. it still fires on carb cleaner.i have fuel pressure and i hear the pump cycle when i turn the key. also the inertia switch is down. what else could it be????? please any suggestions will help.
Old Sep 15, 2002 | 04:11 PM
j_bonham69's Avatar
oh it only stays running if i continualy spray carb cleaner into it. if i stop spraying it dies.
Old Sep 15, 2002 | 10:37 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
what is the fuel preshure? you have to have at least 20 psi in order to keeep your car running, but you should be at 40 check it out with a fuel preshure gauge and see whats up. if it is low it would be you fuel preshure ragulator, or you might have bad injectors.
Old Sep 16, 2002 | 03:48 AM
Sciguyjim's Avatar
You might want to change your fuel filter also.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
