What's that hum in the rear?
Old Sep 15, 2002 | 10:11 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Just curious if this is normal, as I'm pretty new to the TPI group. I got a 86 IROC, 305 TPI, auto. It primes fine, starts fine, accellerates fine, no misfires or anything. My question. At idle, stopped at a light, etc, I hear this humming noise from the rear. Give it alittle gas, it goes away. As I accellerate, sometimes I hear it, sometimes I don't.
Should I anticipate replacing the fuel pump soon, or is mine working normal?
Old Sep 16, 2002 | 12:38 AM
Kevin 88's Avatar
Car: 88 Corvette
Engine: 400, AFR heads, ZZ9, SuperRam, 730
Transmission: Slushbox
Only thing back there is the fuel pump. The pump on my high mileage '85 made more and more noise - especially after I ran it out of gas - but I totalled the car before I could replace it.
Old Sep 16, 2002 | 06:09 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
So should I anticipate replacing it soon? The car only has 83k miles.
Old Sep 17, 2002 | 12:43 AM
Kevin 88's Avatar
Car: 88 Corvette
If it is getting progressively worse, you should probably replace it. If not, it could last a long time.
Old Sep 19, 2003 | 11:08 AM
camaro89RS's Avatar
A few days ago I started to hear a hum from the rear. I hope that I dont have to change the fuel pump anytime soon, no $$.
anyone else know anything about this???
Jason
Old Sep 19, 2003 | 05:04 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
The pump in my IROC makes a lot of noise. It could be an after market pump in there already. Those tend to be a little louder anyway. If its the original, I would just make sure it doesn't get worse and try to keep a half a tank of gas in it at all times. That'll help the pump stay cool and hopefully get you past the 100k mile mark. Then I would seriously look into replacing it w/ a 255.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
