Fuel Pressure Requlator install
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Hey I am getting to installing my fuel pressure regulator and was wondering if anybody had any tips for the install or anything I should watch out for.
Is there anything else I can do to boost the performance since I will have it apart?
What is the best PSI you guys found worked for you.
Most AFPR's require some grinding on the plenum for clearance. I had the Crane Cams regulator and it was a pain to adjust. Now I have the Holley unit and it is much nicer. I recommend getting the current fuel pressure before doing the swap, and start there or 2psi higher.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I second that. Don't adjust it blind. You'll blow something up..
I've found 42PSI works good if your burnng proms. AFPR is a tool to compensate.. Its not the end all fuel enhancer.
You got a security bit set?
-- Joe
-- Joe
Yeah I got the bit set I am hoping the plenum is going to come off easy. I was just looking at opinions on how to do the job right from the ones who know. This is my first TPI. I am pretty good with carbs and I love the simplicity of TBI but it was time for something diff.
Thanks keep the info coming
Brian
Brian
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Just disconnect the vaccume lines (including
brake), unbolt the top runner bolts, push the plenum back, pull up on the back, then pull straight out.
I have mine off a lot.. I use the SLP runners which are a little easier, but you should be ok.
Make sure you don't tear the diaphram when you put the new cap on..
-- Joe
-- Joe
Thanks thats the info I needed guys. I think you all just made it a much easier job for me.
Brian
Brian
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
