Question about Closed Loop?
Old Sep 18, 2002 | 06:38 PM
90FormulaL98's Avatar
Car: 1990 Formula 350
Engine: L98 350
I am running Moates software and the car is running in closed loop and staying there. I drove for an hour and it never changed. What does closed loop mean?
Gary
Old Sep 18, 2002 | 07:26 PM
ROC-Z's Avatar
Closed loop happens when the O2 sensor gets hot enough to start sending voltage to the ecm, telling the ecm of the oxygen content of the exhaust, so the ecm can adjust the fuel/air ratio to 14.7:1....Closed loop is a good thing.
Old Sep 21, 2002 | 12:09 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Martha Stewart couldn't have said it better.
Old Sep 21, 2002 | 03:54 AM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
How do you know you're in closed loop without any specialty tools?
Old Sep 21, 2002 | 05:45 AM
Morley's Avatar
For most it is just something that you learn to recognize. different things will tell you it entered closed loop, ie ; idle drops, idle gets smoother, TC lockup occurs at the programmed speed and just the overall sound and "feel" of the engine will let you know.
Old Sep 21, 2002 | 06:17 AM
scottydta's Avatar
Car: 1989 Trans Am
Transmission: 700R-4
put a jumper in the ALDL connector like your gonna check for codes and start the car. when the light blinks very fast (like twice per second) your in open loop. when it slows down and comes on then goes off maybe once a second then your in closed loop. but it will vary while driving at different loads. when the light is on your running rich, when its off it's lean. it should come on and go off constantly. this way you know your O2 sensor is working properly and the computer is making the adjustment. should stay on fully at WOT.
Old Sep 21, 2002 | 12:07 PM
86ZZ4's Avatar
on my car ,when it enters closed loop the cam sounds a lot quieter,closed loop takes away pretty much all the lope it has,which isnt much
bamaboy0323
Sep 3, 2015 06:07 AM
CORV3TT3
Aug 23, 2015 11:26 AM
beast94
Aug 20, 2015 06:44 AM
redmaroz
Aug 16, 2015 11:40 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
