Is there any advantage to a 255 lph in-tank fuel pump?
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
I'm curious to know if there's an advantage in installing a 255lph in-tank pump rather than a stock replacement pump. Really the flow is ultimately restricted by the regulator, right? I have an adjustable one on my 90 Iroc 305 5 speed. This weekend I hope we'll get a pump in. I just don't know if I should get a stock replacement or a performance aftermarket piece. The only mods I have that would partly play into needing more fuel is the unrestricted exhaust (gutted cats) and Ed-wright chip. Everything else is just basic bolt-on stuff. I'd post my mods, but it's a really really long list. Thanks for any help you can lend!
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Since it is a PITA to install the in tank pump, I would put one in that will fulfill your future needs as well as your present. The regulator restricts the flow AFTER it feeds the injectors.
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
The stock replacement Carter pump has a shut off of 50 psi, so I can't really crank up the pressure with my AFPR can I? What psi should I run with my 305?
The pressure that it runs best at, usually from 45-50 psi, every engine is different. I know a guy that runs best at 38 psi, so never know until you test.
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
