Anyone have a 3-wire heated O2 sensor and know part#?
Old Sep 23, 2002 | 08:55 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
In my quest to get a new O2, I've discovered mine is a 3-wire heated one thats wired into the ECM. This is not a factory TPI but a conversion from my TBI in my '94 Silverado.
Anyone else have a 3-wire heated O2 sensor and know what the AC Delco part# is for it?
Old Sep 23, 2002 | 09:44 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
You can browse the GN web page as well.
I used an AC Delco AFS-74. I believe it was a common part on a 95 S10 with a 4.3.
It depends what plug you have on your harness. There are a few numbers close to the 74, like 72, 73 which have different ends on them. Same sensor.
FYI: There was never a heated O2 as a factory sensor in a TPI.
Mark.
Old Sep 23, 2002 | 09:57 PM
2QUIK6's Avatar
Thanks for the info Mark, I was suspecting the AFS74 since that was original equip on the original TBI motor in the truck and I remember when I installed the wiring harness, the old one fit in the harness connector ok, but I replaced it with the O2 sensor that came with the conversion kit.
Yes, I quickly discovered that there were no 3-wire O2s for the TPI when I started looking for a replacement via several AC parts vendors.
86IROC112
Nov 27, 2015 09:54 AM
85 Jimmy
Sep 30, 2015 07:56 AM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
fonzie85
Aug 13, 2015 11:50 AM
