project: stealth ram (90% complete)
Old Sep 26, 2002 | 10:06 PM
u r sofa king we tah did's Avatar
after some delays i finally got to put my stealth ram on today. all i need now is a water neck for the thermostat, bolt on plenum and hook up the spark plug wires and fire it up! cant wait until tommorow.
Attached Thumbnails project: stealth ram  (90% complete)-dsc00007.jpg
Old Sep 26, 2002 | 10:07 PM
does anyone else think the gaskets supplied with the stealth ram are a joke? they look like construction paper, but flimsier.
Attached Thumbnails project: stealth ram  (90% complete)-dsc00010.jpg
Old Sep 26, 2002 | 10:08 PM
last one
Attached Thumbnails project: stealth ram  (90% complete)-dsc00011.jpg
Old Sep 26, 2002 | 10:10 PM
cobrakiller1989's Avatar
is that fuel puddled up all over the intake?
Old Sep 26, 2002 | 10:15 PM
yes it was due to my brother turning the key on to listen to the radio while i was still getting everything hooked up, it sprayed my face too
Old Sep 26, 2002 | 10:21 PM
that sucks, atleast you didnt do what i did....nevermind we wont talk about that...
Old Sep 26, 2002 | 10:31 PM
does anyone make a fuel pressure gauge that works with the tire valve fitting holley supplied?
Old Sep 27, 2002 | 12:25 AM
bigals87z28's Avatar
Car: Check The Sig
it looks like ****... *** i cant stand the look of that HSR on your car... u should give it to me! hehehehe its lookin nice man... sucks about the fuel thing... i hate lil brothers in the car when im under the hood.... they think its funny to start it up when im gettin the runners off!.... f**kin basterd...
Old Sep 27, 2002 | 06:48 AM
Cam28_boy's Avatar
what size for your fuel line
Could you give me the size of those fittings you used for the fuel line? Also what size fuel line you used.
Old Sep 27, 2002 | 10:11 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Yes, when I first put it together, I didn't have the gaskets & I used RTV with no problem. I then had to take it apart to reseal the rear of the intake (oil leak) & laughed at them, coated both sides with a THIN layer of RTV & all is well.
Old Sep 27, 2002 | 11:07 AM
Re: what size for your fuel line
sure thing bud...
the feed line is EAR-9894DBJ and at summit it cost like 7.95
the return line is EAR-9894DBH and cost the same 7.95 from summit
both of those fittings are saginaw to -6AN fittings, so my braided line is -6. if you go this route, get a dremel., cutting steel line with a hacksaw is a joke. the stealth has -6AN fittings so you will need 4 SUM-220690, which are -6AN female hose end fittings. doing the fuel lines like this made it a snap.
Old Sep 27, 2002 | 11:55 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Rick,
I told you they were a joke.LOL. about the envelope i sent them in was better then the gaskets it comes with.
BTW, You got e-mail.
Old Sep 30, 2002 | 05:29 PM
dont try to put your distributor in at 3:45am after you have been up for 2 days. i had the damn thing in 180 degrees backwards. after correcting this and getting it running, it turned my car into an animal. there is no more "tpi wall" thats for sure.
Old Sep 30, 2002 | 08:37 PM
Stang Eater's Avatar
I took the tire fitting valve out of my rail, and then screwed my autometer PSI gauge right into the rail. Easy to see while tuning for my, because i installed the rails with the regulator on the front passenger side, and it was at the rear, even ended up at the right angle when tight!!!! just my .02
Old Oct 1, 2002 | 12:16 AM
might have to try that...
Old Oct 1, 2002 | 12:27 AM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
I believe another member stated the FP regulator is an ~87 GN type.
Old Oct 1, 2002 | 01:11 AM
i have the adjustable reg, we are talking about fuel pressure gauges.
Old Oct 1, 2002 | 02:34 AM
Engine: 3.6L
I guess I was thinking they used their style FP regulator and valve port for a design standpoint. I wonder what the imports use as a standard on the fuel rail port?
Old Oct 2, 2002 | 12:57 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
fittings
i feel for the people that have a nitrous kit and has to have the schrader valve for the feed line.....
it took me 4 hours to track down the exact fitting it needed....
for some reason no one here has any 90* barb fittings
Old Oct 2, 2002 | 01:31 AM
IROCFAST's Avatar
The accel guage will fit right on there. It is for a "schrader" valve application.
Old Oct 2, 2002 | 04:02 AM
what size is that cheasy pressure valve thread, 1/4 NPT? if so is there a 1/4 NPT to schrader valve adapter?
Old Oct 2, 2002 | 08:08 AM
Ricktpi's Avatar
Where the valve threads into the rail is 1/8 NPT.
Old Oct 2, 2002 | 04:38 PM
so is there a 1/8npt to schrader valve adapter.
Old Oct 2, 2002 | 07:08 PM
rezinn's Avatar
Looks good other than the silver spraypaint on some things
Channel locks/vice grips = very useful. Get it running yet?
Old Oct 3, 2002 | 02:34 AM
been running for a while with the cheasy valve for a bit now, and the paint is already fixed with the color of the car and chrome highlights, and new hoses-belt.
Old Oct 3, 2002 | 12:06 PM
Ricktpi's Avatar
Sofa King,
If you want a permanent mounted FP gauge, remove the schrader valve altogether & use the 1/8 npt hole with the gauge. Most aftermarket gauges can use a 1/8 npt feed.
Old Oct 4, 2002 | 04:42 AM
Cam28_boy's Avatar
Thanks for the information sofa king!:hail:
Old Oct 6, 2002 | 11:54 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Go to a refrigeration supply house. They have the 1/8 to schrader fittings. That's what I used in mine.
Old Oct 7, 2002 | 06:15 PM
testing out pic...
Attached Thumbnails project: stealth ram  (90% complete)-dsc00003.jpg
Old Oct 7, 2002 | 06:26 PM
Black91Z28's Avatar
Car: 1991 Camaro z28
Engine: 350 Tpi
Transmission: 700r4 Auto
how's hood clearance?
Old Oct 7, 2002 | 06:41 PM
woah, can you come paint my engine bay like that? jk
Old Oct 7, 2002 | 07:11 PM
hood clearance is fine. doesnt hit at all. the paint is all primer. i havent decided if i should paint it all black or white like the color of the car, so until then its dull primer.
Old Oct 8, 2002 | 02:27 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
how much did you spend on the stealth ram all togeather if I may ask?
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
Stangski09
Nov 14, 2015 01:27 PM
MORREALE5
Sep 13, 2015 09:01 PM
R3500
Sep 8, 2015 10:12 PM
09ave
Sep 7, 2015 06:03 PM
