How does this cam sound?
Old Oct 12, 2002 | 08:19 PM
Nasty_Bird_'90's Avatar
Just looking at the Lingenfeter site and came across this cam:
224/234 .496/.520 112LSA
Do you think it is too radical for stock heads?
Should i go with this:
214/224 472/496 112lsa
Will have headers, 2800stall, and other small bolt on's as well.
Old Oct 12, 2002 | 08:40 PM
Sleeper_Z's Avatar
Car: Golden yellow 1987 IROC-Z
That is the ZZ9 TPIS cam right? If it is that is a good cam for mid range torque, but you will need new springs. You wont get full potential out of it till you do an intake and runners swap. But it is a very good street/performance cam. Hope this helps alittle.
Sleeper_Z
1987 IROC-Z
350TPI (internaly stock)
700R4 w/shift kit and vette mods
9-bolt w/3.27's
Mods:
Edelbrock T.E.S.
no converter, flowmaster cat back
K&N's, ported upper plenum,
Holley air foil, Crane AFPR @48psi,
Olson race Cars SFC's, Eibach springs,
Poly bushings and mounts
Best R/T .503
Best 60' 2.03
Best 1/8 9.23@75
Best 1/4 14.44@97.34
Old Oct 12, 2002 | 09:31 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
That Lingenfelter cam is too big to use with the stock tpi and heads, that cam is more suited to a Holley Stealth Ram or LT1 intake.
The 214/224 cam you list sounds ok, I wouldn't go with any cam that has larger duration with a long tube runner tpi setup.
Old Oct 12, 2002 | 09:45 PM
Cool thanx guys
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
db057
Sep 4, 2015 07:57 AM
db057
Aug 22, 2015 08:17 PM
