Possible fuel pump problems
Old Oct 14, 2002 | 05:55 PM
HI92Z28's Avatar
Engine: stock 350 TPI
Transmission: rebuilt stock tranny, b&m shiftkit
A few days ago I left lower fuel than usual, usually when it gets 1/4 tank I will fill it up. I noticed while it was low on fuel I heard the fuel pump sounded weird. I know that low fuel will damage the fuel pump, but this is the first time I let the fuel go that low. Well after I filled it up a few days later while driving and had to suddenly stop, then I noticed the same sound from the fuel pump when fuel was low.
Are these F bodys known to fuel pump problems? I heard its a pain-in-the-but to change and the complete exaust has to be droped. I also have my cats out so its one piece from the manifold on.
Old Oct 14, 2002 | 07:54 PM
m300slr's Avatar
Car: 1985 Z28
Axle/Gears: 3.90 10 bolt eaton posi
I have had a lot of fuel pump problems with mine. I had a bad connection at the fuel pump and it would quit on me all the time. I could take the pump out and put it back in in less than 5 minutes, and it would work again for a day. Anyway, I replaced my fuel pump and it has alwase been pretty loud. I can hear it buzzing in the tank. But if you ever want an esier way to take out the pump, cut a hole in your trunk, it does not take much time. The guy who owned mine before cut a hole right above the pump and this is why I can fix it in 5 minutes. Just be carefull not to cut the tank.
Old Oct 14, 2002 | 08:00 PM
HawaiiB4C's Avatar
Replaced fuel pump on my old '92 Z28 5.7L and it was a P.I.T.A., however thats how it goes. The only way to do it is dropping your exhaust and also dropping the rearend as far as it will go, removing the fuel tank, be careful with fuel neck, and replace fuel pump and strainer. this whole process takes about 4-6 hours and a couple 12 packs. Some people will tell you to cut out the section in the back hatch compartment just above the fuel tank. Don't do this, it is called cheesedicking. Remember to empty fuel tank prior to removal.
Old Oct 14, 2002 | 08:55 PM
HI92Z28's Avatar
If I remove the exaust do I still have to drop the rear end?
Old Oct 16, 2002 | 07:31 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
yes the rear end needs to drop all the way down
cheesedicking takes about an hour
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
