aftermarket base questions
Old Oct 17, 2002 | 05:49 PM
WS6Formula350's Avatar
With the accel superram base can you use slp or edelbrock runners or it has to be the accel ones?? i know that the stock ones work. Also do u have mess w/the computer after installing one of these bases along w/porting, polishing and 3 angle value job w/the heads???I don't see why you would but just wanna make sure b4 I mess something up.
Old Oct 17, 2002 | 06:20 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
any runners will bolt up to any base....you dont have to burn a prom..but im sure if u do itll run better..
Old Oct 17, 2002 | 06:29 PM
jd13's Avatar
Yeah just about any aftermarket runners will work with the base. As for a prom, you don't need one, but it's highly recommended.
Old Oct 17, 2002 | 10:33 PM
Swapmaster's Avatar
The stock prom will only go so far. You will reach a point when the
car either will be hard to start or will run worse after you add
something to it. That is when you will need to burn a prom.
Don't buy a custom prom either. Your car will need to be in the
hands of the person burning the prom to get the job done right.
Old Oct 18, 2002 | 04:07 PM
Ok so my next question would be...anyone from NY possible on the Island know or actually burn custom proms. I know it's pretty cheap to get started into but i really don't plan on any other mods then the intake, runners,ported plenum and some rebuild heads. I don't have alotta free time between work and school to fool around w/this being that this is my only mode of transportation.Thanks guys you've been a big help as always.
I know about fastchips but would like something local. I'll do it if i have to
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
