Has anyone had a fuel pump put in by the dealer service department???
Old Oct 19, 2002 | 04:54 AM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
If you don't mind my asking, how much did that cost? The reason I ask is, I just don't have the time with school and everything, and my dad's schedule is tight too. I asked a guy I know who works at a Saturn dealership about what it would cost and he told me he'd do it on the side. He's going to call with more info. What do you guys think?
Old Oct 19, 2002 | 08:18 AM
Morley's Avatar
I "think" they quoted me like $250-$300 to do it about 8-9 years ago. Too freakin expensive, I set aside 4 hours and did it myself (only took 2-3 hours to do it).
Old Oct 19, 2002 | 04:33 PM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
He said he'd do my shocks and lowering springs too. So hopefully it'll turn out all right, I'll just have to see what he wants for the job. Thanks for the comparo though!
Old Oct 22, 2002 | 08:42 PM
89Irocz23's Avatar
haha I was a idiot when I bought my car. I had them do a comp check to see what was wrong with my car. They charged me 90 for that and it was a bad fuel pump. With everything it was $420!!! I know its crazy but I didnt know how to do anything at the time.
Old Oct 23, 2002 | 07:42 PM
pmalski's Avatar
I just had mine replaced by the dealer this spring. It was $525.82 ($113.32 for pump $412.50 for labor)
Old Oct 23, 2002 | 09:26 PM
Bort62's Avatar
Jesus christ for 425 Ill drive out there and Change it for you
Old Oct 24, 2002 | 12:44 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I also had mine changed 2 years ago and it cost about $400 or a little less. But at that time I didnt have the space to do it but now I am kicking myself for paying that.
Old Oct 24, 2002 | 05:43 PM
camaro6spd's Avatar
SCREW THAT, it cost me $54.....NAPA fuel pump and installed it in a weekend....it did suck tho.
Old Oct 25, 2002 | 10:38 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I just installed a syclone pump in my 87. Filled it up with gas, and has a huge leak from the top of the tank. I put the new o-ring that came with the pump in when I changed the pump. It was identical to the one I pulled out, and the one I pulled wasn't leaking. Since there is no other place the fuel could be leaking (not coming from the filler neck) I went to chevy and got a new o-ring. The one they gave me was not really an o-ring at all. It's more of an oval, and has a steel core to it, and three locating tangs. Cost me $9.35. Part# 22515965. If you change your fuel pump, spend the extra $10 to get this gasket. I'm having to pull my tank again tomorrow to put a $10 gasket in. Sucks big time.
Dan
Old Oct 26, 2002 | 06:23 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
I think the Chiltons Labor Time Guide lists the 82-92 pump at around 4- 4.5 hours of labor. Throw in 1.0 hr for diagnosis and you're at about $360-$400 for labor alone.
Then the pump, dampner, and strainer run about $150......
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
