Need advice, sick Firebird
Old Oct 19, 2002 | 05:59 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
What would cause all 8 injectors to stop pulsing and remain in the open position?
This happened a week ago, like someone turned off a switch. I was driving home from work all was fine, then the car stalled, I started it back up and it ran like sh*t, coughing and skipping the rest of the way home.
Last night I started the car and put my finger on each injector,
normally I can feel them click, but not this time. I really doubt that all 8 injectors failed at the same time.
Would a bad ignition module cause this, or should I be looking
somewhere else.
Thanks.
John
Old Oct 19, 2002 | 06:25 PM
Morley's Avatar
Pull the connector for each injector and turn the ignition on, put a test light across the pins of each connector and see if it lights up, if it does then something is shorted somewhere.
It is highly improbable that all 8 injectors failed in the open position, their power off mode is closed, so even if they wern't pulsing the car shouldn't run at all.
Old Oct 20, 2002 | 09:42 AM
Problem solved, it was a blown fuse.
jhawkeye
May 25, 2022 06:33 PM
xkingcodex
Feb 12, 2020 07:43 PM
theshackle
Mar 5, 2017 06:37 PM
E Rod
Aug 28, 2015 05:17 AM
justin57
Aug 20, 2015 07:05 PM
