LT1 ?'s
Old Oct 21, 2002 | 08:31 PM
nickyg's Avatar
Car: '91 TA Green
LT1 ?'s
How difficult to install by yourself? How much will it cost? Pro's? Con's?
Old Oct 21, 2002 | 09:17 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
There is so much info on this topic, do a search or go over the the motor swap board and read the posts there
https://www.thirdgen.org/techbb2/sho...threadid=84423
Old Oct 22, 2002 | 07:58 AM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
if you can take your TPI off, you can put your LT1 on blindfolded.
Intake is 1 peice, fuel railes bolt on top, plug in some fuel lines, run some coolant lines.
MAKE SURE you get the rite gaskets or it will smoke like a bitch due to the EGR port in the heads dumping exhaust into the crankcase.
I am barely even a backyard mechanic, and I pulled my intake, changed the intake gaskets, put it back together, put knock sensor in and blah blah blah before noon on friday,
Old Oct 22, 2002 | 09:46 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Oh, are you talking about a lt1 intake or lt1 engine?
Old Oct 22, 2002 | 10:46 AM
86FyrBrd's Avatar
Good point, I just assumed intake for some reason
Old Oct 22, 2002 | 01:53 PM
nickyg's Avatar
Car: '91 TA Green
Yeah intake sorry i didnt specify anout that...no real reason to post an gen engine question on the TPI board... i just want to make my car a little more efficient... still searching but just decided to put it flat out... may help other people too
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
