Best cam for an 86 305 IROC
Old Oct 23, 2002 | 05:07 PM
Striker27's Avatar
Car: 1986 305 IROC Z
Engine: 305 tpi
The car in question is an 86 IROC with a non roller cam. I was wondering what the best cam would be for it out of all the choices out their. I do not want to go the custom chip route or have an undriveable beast. The car has now an airfoil,AFPR,Flowmaster cat back, hooker 2055's headers,a chip of unknown manufacturer,Taylor wires,Accell coil,shift kit,3.42's,ported plenum, 150 hp nos kit. Any help at all would be appreciated. THANX
Old Oct 24, 2002 | 07:37 PM
iroc_cragg's Avatar
What does ur '86 IROC do in the 1/4 mile.
With and Without the NOS
Old Oct 26, 2002 | 04:55 PM
mckenzie's Avatar
when i rebuilt my 305tpi in my 86 iroc, i went with the comp cam with a .444 lift on intake and exhaust...seems to do pretty good. when the cam came in, it said for a 350tpi. i called comp cam's and they said it will also work on a 305tpi. i still run factory prom. might be a better cam out there, just wanted to let you know what i have in mine...idle and vacuum is good. best of luck, tom
Old Oct 28, 2002 | 08:59 AM
ninjairoc's Avatar
Car: 1986 Camaro IROC-Z
what do you guys run in the 1/4 mile?
Old Oct 28, 2002 | 09:25 AM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
cam
i went with a compucam 2030.... worked great .... but i am now going one step up i belive the 2040 with 1.6 roller rockers...
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
