Guys, what Intake Option would I have if I go with Vortec heads?
Old Oct 26, 2002 | 06:11 PM
bzznczzn's Avatar
Are any of the aftermarket systems (ex MiniRam, super ram, stealth ram etc ) compatable with vortec heads? How about LT1 intakes?
It's hard to beat the performance per dollar of those heads, but I do not want to be perminantly stuck with just TPI if I go that route.
Old Oct 26, 2002 | 10:33 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
You can use the SDPC vortec base and the superram runners and plenium with the vortec heads. You can also use the mini ram that is designed for vortec heads.
Old Oct 27, 2002 | 01:00 PM
bzznczzn's Avatar
Thanks man, one more question. How does a sr base differ from the modded tpi base for vortec heads? Is it basically the same? In other words will it allow the same benefits that a supperam is known to give you or would it alter it's effect?
Old Oct 27, 2002 | 02:52 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Its basically the same, the superram/vortec base is larger then the stock TPI base but the same stock will work ok with a superram. For max power the Vortec base would be better then a TPI base but a TPI base will work.
Old Oct 27, 2002 | 03:58 PM
bzznczzn's Avatar
Thanks for all the help guys. How much do the sr runners and plenum run? What do they run used? Seems like this would make a pretty damn good combo.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
