what is a ccv
Old Oct 26, 2002 | 08:13 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
what is a ccv
I am missing it what ever it is along with the tube that goes from it to the tb the hole it is suppose to be in is in the back of the passenger side valve cover
Old Oct 26, 2002 | 08:48 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
It is called a PCV is a positve crankvase ventilation. It draws the fumes from the crankcase and blows it back into the throttle body. This is a emissions related item.
Old Oct 26, 2002 | 09:35 PM
c4boom's Avatar
Engine: l98 and lo5
No that’s on the drivers side and hooks into the whole below the one that I mentioned in the TB
Old Oct 26, 2002 | 11:33 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
CCV means crankcase vent. Two of the holes in the throttle body are for water passage. The third has a hose with a metel tube connector simalar in appearance to a PCV valve that plugs into the passenger side valve cover to allow filtered air to be sucked into 1 valve cover thru the engine and out thru the PCV valve.
Old Oct 27, 2002 | 01:50 AM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
whoops, its been a while, i had two breathers on my valve covers
88formula305tpi
Jan 13, 2021 08:43 AM
bijjincam88
Jun 26, 2011 06:47 PM
MP81
Jan 27, 2008 09:57 AM
david auster
Dec 31, 2003 12:30 PM
Vader
Mar 10, 2002 10:11 PM
