TPIS Mini-ram III.......??????
Old Oct 27, 2002 | 01:04 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Will this intake work with Vortec-Iron heads? If so , how much is it? If my SDPC vortec TPI intake doesnt come in soon, I'm going to get my money back and look into other options !!
Is anyone on this board running a Mini-ram III??????
Mike (1bad91Z)
Old Oct 27, 2002 | 08:35 AM
e-man's Avatar
Car: 89 formula
Engine: 383
It is made for the vortec-fastburn heads its just as much $$$$ as the regular miniram. http://www.tpis.com/
Old Oct 29, 2002 | 09:56 AM
tpi_roc's Avatar
Just for good measure...
Dont buy fastburns!
Old Oct 29, 2002 | 02:11 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Whats wrong with the fast-burns?
Old Oct 29, 2002 | 02:52 PM
tpi_roc's Avatar
Its nothing other than one mans opinion
But there is another thread somewhere floating around this board where I had just gotten back from the machine shop where I laid out every aftermarket SBC head imagnineable on a table and started comparing them on engineering and workmanship points...
The fastburns were probably by far my least favorite due to a few things like the valves, the bolts around the coolant passage (angle and location) and the roughness of the cast, and minimal machine work
The only good point to them is they were probably the lightest or at least they had the least material around the intake runners, which may be a bad thing if you like to go crazy with a die grinder.
Only opinions
Old Oct 29, 2002 | 02:53 PM
tpi_roc's Avatar
Oh yea...
not to mention the incompatibility with fastburns... I like being able to use *any* SBC intake on my heads instead of only the 1 option for fastburns and EFI, or the one or two options for carb guys.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
