Injector Ecm-calibration
Hi.
(My car is a Corvette 1990 L98 man 6-shifted ORIGINAL this far)
Could any of you pro's help me out calibrating my new
Injector flow rate constant.
As it is right now i'am using the original injectors.
Tunercat says my flow-rate is 22.1
Now i'am about to replace those with FORD SVO 24#, but still
use my original fuel-pressure.
So how and what should the new value of the Injector flow rate be?
(Yes i know, there is a FAQ, but i really wanna be sure one this one)
I got 25.9# as my inj constant when I switched to those injectors, fuel pressure set to 45psi.
As Bort said, the only way to be sure is w/ a scantool and watching the BLM data to see if the ECM is adding or subtracting fuel.
Ok. I will go for initial 25 and then wath the Block learn.
But, can i just let my car idle and get a feeling for this or do
i need to take it for a ride? (mabey stupid question but like
i said i don't wanna fry my machine
) I agree at high 25 low 26 range, but that doesn't mean you'll be anywhere close...
I have LT1 injectors in my car at 2 psi over the stock range and I can take my injector constant up to about 30 and still be rich, I ended up having to almost half whats in my VE tables under 4k, and increase over...
so who knows, a scan tool and testing is all you can really do.
Car: Death Mobile
Engine: 666 c.i.
Originally posted by dahlman
A local tuner company said that there is no way i'am going
to get a good idle with my Ford SVO #24's. Because they were
way to much for my original engine.
Is this true?
Is this true?
I would also recommend that you readjust your IAC for idle after you install the new injectors and run your first "modified" bin wit the new injectors. I find that helps a lot in resolving some idle issues.
thejimsterz28
Sep 15, 2015 04:37 PM
