Porting plenum, runners, and base
Old Oct 27, 2002 | 06:09 PM
Nasty_Bird_'90's Avatar
Just wondering what kind of gains you guys are getting from porting out the TPI system. I'm doing it no matter what just because I have nothing better to do, but i was just wondering what to expect.
Old Oct 27, 2002 | 09:45 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
if you have a LO3, expect nothing. You have to have a moded 350 before you really see a difference
Old Oct 27, 2002 | 09:53 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
I dont know - but ill say this:
Youre going to see substantial gains if you decide to take it two steps further after porting/polishing and get a heads/cam set.
I dont have any experience with how much gains stock youll get with the porting, but for sure the more aggressive heads and cam will eat up the extra air.
Old Oct 27, 2002 | 09:56 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
oh yeah - be sure to get an adjustable fuel pressure regulator to up your fuel along with the higher demand of the engine.
Old Oct 28, 2002 | 04:56 PM
It's actually going on a L98 I'm building. Where is the plenum and runners on an L03 to port out? . I'm putting a cam in it as of now....heads are later, when money allows.
Old Oct 28, 2002 | 07:15 PM
Bort62's Avatar
Are you planning on Siameseing, or just Gasket matching and radiusing the Runner/plenum Junction ?
Old Oct 28, 2002 | 07:50 PM
I already have the upper plenum opened up and siamesed. I'm using the SLP runners, so I guess i should go ahead and siamese the lower manifold and make it all worth while.
88SS6SPEED
Nov 11, 2015 07:05 AM
85 Jimmy
Sep 30, 2015 07:56 AM
mrestrictrplate
Sep 21, 2015 11:24 AM
alpine247
Sep 16, 2015 05:25 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
