porting intake and runners
Old Oct 28, 2002 | 09:06 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
I was wondering if siamese porting the runners or the lower intake was the better thing to do. I have the edelbrock intake and runners so I could siamese either one of them. currently i am running.
355
vette heads
zz9 cam
9.5:1 comp
intake/runners
24lb injectors
I also have a paxton charger not on car at the moment
anyone have any ideas on which one i should siamese and how far i should go.
Old Oct 29, 2002 | 09:53 AM
tpi_roc's Avatar
I dont recommend siamesing the Intake, I gave it a shot basically because I wanted the RPM's more than the torque but in the end its just a slower ET, the trade off isn't a fair one.
Old Oct 29, 2002 | 07:32 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
i ported the stock base for my engine. and i still gained torque at the bottom. i'm up to 362.9rwtq @ 2700 right now.
Old Oct 29, 2002 | 07:37 PM
tpi_roc's Avatar
ported or siamesed?
Old Oct 29, 2002 | 07:39 PM
mrr23's Avatar
Engine: 360 HSR
well siamesed to be exact. here's a pic. now all i need to do is get rid of the stock runners. get some SLP and completely siamese them.
Old Oct 29, 2002 | 07:56 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
thanks for the info. I think I will try siamesing the stock lower that i have in the closet to see if it helps me on the upper rpms.
Old Oct 29, 2002 | 08:02 PM
mrr23's Avatar
Engine: 360 HSR
when you do the siamesing, you may cut through the bottom portion in some areas like i did. you will need to have them welded shut. i ended up cutting through 5 areas where the ports go along the bottom. when you look at the intake from the bottom, you'll see thin areas where the ports run along the bottom.
Old Oct 29, 2002 | 09:02 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
how much more rpm would your motor turn after porting your intake?
Old Oct 29, 2002 | 09:46 PM
mrr23's Avatar
Engine: 360 HSR
you can see by the dyno that it started picking up at the 3500 mark. but, because of the stock runners still on it, it still peaked at 4400 rpm. also the l98 heads i ported. so my next step to increase rpms is to get some SLP or AS&M runners and completely siamese them.
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
toronto formula
Sep 10, 2015 07:31 AM
