LT1 intake bolt holes
Old Nov 1, 2002 | 03:11 PM
Swapmaster's Avatar
This may be a stupid question, but, has anyone put on an LT1
intake and left out the 4 center bolts?
I have one of John's intakes here and am mocking up the engine
to see how the intake lines up and the center bolts look like they
are a bitch. I have an idea of sealing the center bolt holes in the
manifold with JB and just using the 8 corner bolts around the
coolant passages.
The Vortec engines get away with it, so why cant we?
Old Nov 1, 2002 | 04:26 PM
rezinn's Avatar
Old Nov 1, 2002 | 04:29 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
the vortec intakes can do it because they use a different style of gasket, if you do it it WILL leak. you can use allen head bolts and they should fit.
Old Nov 1, 2002 | 07:27 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
It looks like you ordered a late style bolt pattern and the heads are actually early style bolt pattern.
evilstuie
Jan 9, 2020 08:29 PM
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
midge54
Jan 29, 2017 07:00 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
