EGR maybe?
Old Nov 14, 2002 | 09:31 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
EGR maybe?
I think my egr is bad. The idle is rough, anywhere from 500-1500. It starts cold but chokes out, and when cruising it bounces 500 RPM when going 30mph. At idle there is a high pitched whistling noise coming from the valve. I can here it a when driving, but when I hit the throttle the noise disappears. Is the egr bad?
The car didn't throw the egr code, just 34, the MAF.
What type is it(ported, pos pressure,neg pressure)? The engine is a '89 305 TPI, the car and ECM is a '85 TA. What do you think the problem is?
Old Nov 14, 2002 | 09:35 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Um, I think the problem is the MAF....
Old Nov 15, 2002 | 11:00 AM
Vader's Avatar
You will get a '34' with a large vacuum leak, such as an EGR leak. There are also other possible causes for your symptoms. What is the idle vacuum reading?
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
