TPS voltage
Old Nov 18, 2002 | 06:00 PM
HI92Z28's Avatar
Engine: stock 350 TPI
Transmission: rebuilt stock tranny, b&m shiftkit
TPS voltage
I'm doing the TPS and th IAC procedure, did the IAC allready and doing the TPS with a OTC, with the key on its at .38 and WOT at 4.30 volts. Can't get the votage at above .40 volts. Bad TPS? On my Turbo Buicks the TPS is slotted so the adjustment is very easy on the Camaro is seems it can't be adjusted. The only way to increase the TPS voltage I drilled out the mounting hole to get an increase in voltage but then the idle gets increased.
Old Nov 18, 2002 | 06:18 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
the idle will increase because you are telling the computer the throttle is opening. so it adds fuel and the IAC opens some. di you loosen both screrws? just asking. it should move.
Old Nov 18, 2002 | 06:20 PM
HI92Z28's Avatar
Yes I removed both screws on the TPS but can't get more than .40 volts.
Old Nov 18, 2002 | 06:53 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
You don't need to adjust the TPS on 90-92 TPI cars. The ECM relearns 0 everytime it starts up. And over 4V at WOT is 100% so nothing is wrong there either.
The turbo buick ECM is an earlier, dumber design.
Old Nov 18, 2002 | 07:04 PM
HI92Z28's Avatar
Thanks for the info. I got this off here.....https://www.thirdgen.org/newdesign/tech/tpimod2.shtml should had been more specific for the years I broke the TPS trying to adjust it. Is the IAC reset procedure correct to my car?
Old Nov 19, 2002 | 10:33 AM
MdFormula350's Avatar
i guess that was part of speed density change.. i noticed the difference from my 88 formula 350 to my 91 formula 350..
Old Nov 19, 2002 | 10:41 AM
HI92Z28's Avatar
I wanted to make this clear
So there is no TPS adjustment on my 92 Z28? But do a low .38 won't give any idle problems? Is there a ECM power disconnect under the hood to reset the ECM or I have to just disconnect the battery?
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
327IROC85
Sep 23, 2015 12:11 AM
