starting to port and polish plenum what do u think
Old Nov 17, 2002 | 06:36 PM
pokes87iroc's Avatar
let me know what u think
Attached Thumbnails starting to port and polish plenum what do u think-plenum-2.jpg
Old Nov 17, 2002 | 06:37 PM
last one
Attached Thumbnails starting to port and polish plenum what do u think-plenum-3.jpg
Old Nov 17, 2002 | 08:49 PM
panman79's Avatar
bad pic quality,looks pretty good i think. How long did it take you to do that?
Old Nov 17, 2002 | 10:57 PM
bigals87z28's Avatar
Car: Check The Sig
looks good bro... what tools did u use? im gunna do all that fun stuff when i come home for winter break
Old Nov 18, 2002 | 03:02 PM
the porting didnt take all that long. im useing a dremel with a cord thing its work really good. polishing the top of the plenum is taking the must i only work on it every so often and for a hour. my hand goes numb after any longer then that.
Old Nov 18, 2002 | 05:08 PM
panman79's Avatar
Keep up the good work! polished tpi's always look awesome
Old Nov 18, 2002 | 05:44 PM
Car: Check The Sig
sweeet... i am gunna do mine with my dremmel...so this is awsome...keep us posted...
Old Nov 18, 2002 | 07:28 PM
Chevyguy1984's Avatar
What bits are you using in the dremel tool to port with? I have access to air and a die grinder but its out in the garage and this time of year the garage is darn cold. I am assuming I will need the die grinder and a carbide bit to siamese the base, but if I can port the plenum with the Dremel at least I can get something done in the off season.
Old Nov 18, 2002 | 11:29 PM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
I used a dremmel for my plenum porting. The bit that I used was about 5 cut off wheel discs stacked on top of each other. That took the aluminum right off, then I used sanding rolls to smooth it out. Instead of changing the sanding rolls and going to higher grit numbers, I just wore down the sanding roll. Basically, the roll changed it's grit, instead of me changing the roll.
-Jesse
Old Nov 18, 2002 | 11:52 PM
rezinn's Avatar
All I can see is that you took the egr walls out, but that plenum does look smooth. Good work. I can't wait to take mine apart again, sure beats organic chemistry
Old Nov 19, 2002 | 10:46 AM
MdFormula350's Avatar
looks good!
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 26, 2015 04:59 PM
kah992
Aug 19, 2015 02:55 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mx127
Aug 10, 2015 08:13 AM
