Superram and Sportsman II's
Car: 91 Camaro Z28
Transmission: TKO 600
Axle/Gears: 10 bolt 3.23
I did some searching on the board and found some good things and some bad things about sportsman II's. Is anyone running these heads with the Superram? And if so, how do you like it? What cam did you use? Did you see a loss in torque, down low? And i'd appreciate just about any info you could give me on these heads, and on the setup that you're running.
Wally
Wally
Car: 91 Camaro Z28
Someone out there has to be running a similar setup. Or can at lesat give me an idea as to what to expect from this. I also need help choosing a camshaft.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The Sportsmans are okay, but are better flowing heads out there. Don't expect much from the valve springs World uses, they are crap, especially with an agressive HR cam. I had a set of Torquers with a Super Ram intake, the car ran 13.2 @ 103.
Car: 91 Camaro Z28
Rick, I currently have the Torquers. My friend is offering me a striaght up traid for his Sportsmans. I've been told in previous posts that my heads are the weak link in my setup. So i'm hoping that this should at least be better than the torquers. I will be raising my compression to 10:1 to help with that.
Pac J
May 17, 2020 10:44 AM
[GA] Shorty headers
Night rider327
Sep 16, 2015 02:20 AM
Dialed_In
Aug 20, 2015 01:45 PM
